Will a GS700 power two GTX 760 HAWKS? I have an SSD and a HDD and an overclock of 4.4 with 1.28 V
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/43897-power-question-on-hawk/
Yes it will :)
*ahem*
AWWWWWWWWWWW YEEEEAAAAAAHHHHH!!!!!!!!!!!
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574119
Nice, You have to take pictures with them installed. I've been honestly thinking about finding someone to trade me one for my MSI tf 7950 that is brand new even though the 760 is a slower card.
Yeah. I'll SLI in Christmas most likely. But now, i'll run one card configuration.
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574150
How are those 6-Pin to 8-Pin adapters that they include in many card packaging? Would a configuration such as:
2(Molex) to 6-Pin to 8-Pin work for a GTX 760?
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574658
hm...i dont know how stable molex to 8pin so i would do any heavy OC but you can but a 6 pin in a 8pin slot and run it i think
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574668
I mean 2 Molex to a 6-Pin which then makes a 6-Pin to 8-Pin
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574673
dang...youre playing with fire...literally.
with each new adapter/connection you loose power and stability. one extension is enough i dont know about 2 different adapters.
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574682
Yeah i Guess so. I wanted to run 2 HAWKS and The GS700 Only has 2 6-Pin + 2 connections
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574687
BUT overall. How are 6-Pin to 8-Pins?
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574689
buy new psu
I just got this one!
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574693
wait...so its a 6pin with a smal 2pin hangin next to it?
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574699
Yup. And the little bastard needs 2 8-Pins. What a wonderful discovery! :'(
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574704
are you sure your power supply doesnt have another 8pin?
it says it does?
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574714
send it back then under DSR
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574715
it says it does?
2x 6+2 Pin PCIe Power connectors.
I have revised my plans and thought of 2x Molex to one 8-Pin PCIe. I read it is used alot so i might go with that once i SLI
http://cablesaurus.com/2x4-Pin-Molex--%3E-8-Pin-PCIe-Adapter-Cable
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574734
2x6+2 is two 8pin....why use molex?
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574739
Because there are only 2 of that kind available and i plan to SLI in the future
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574742
*facepalm*
holy talito... its almost 5 a.m. and all my common sense has gone to bed and im here being an idiot...
sorry brain fart  :wacko:
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574748
The two extra wires going from a 6-pin PCI to an 8-pin are both grounds.
Depending on the quality of your powersupply you shouldn't be risking anything using adapters.
You could convert the 4-pin molexs to an 8 pin if you wanted but, it would all depend on the quality of your 12v rail.
If your power supply does not have 4 6+2 PCI connectors as others have stated your probably better off buying a new PSU.
You could make your current one work but you may be drawing too much amps on the 12v rail and run into problems.
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574800
https://linustechtips.com/topic/43897-power-question-on-hawk/#findComment-574845
