Mouse movement cause heavy CPU usage
Go to solution Solved by PiGHamM3R,
I had a similar issue way back in the Vista days. I could never identify the cause, even after running CCleaner and cleaning up the registry. The issue resolved itself when I did a re-install of Windows (clean install)
Hey guys
I recently went to play a game of CS:GO, I noticed massive frame drops from 200+ to ~40. After leaving the game, I uninstalled any recently installed programs (Win10 crap) and tried again in an offline server, the problem persisted, but after noticing it is only caused when mouse movement occurs. I reinstalled my driver and tested if this was directly related to CS, or if it occurred throughout. It does; whenever mouse movement occurs my CPU usage throttles to 90% load with the open program(s) usage increasing.
The phenomenon initially occurred after downloading a game recommenced by PCGamer, some daft 70mb thing, which I deleted as soon as I thought it might have been the culprit but nothing.
After watching my resource monitor/task manager when recreating phenomenon, I have identified that it isn't a single program that throttles the CPU usage, but collectively all running tasks increasing their load, by about double.
I have tried reinstalling mouse drivers/software, as well as using the mouse as a generic usb pointer, which neither worked, I have tried reinstalling AMD video drivers which also didn't work.
And after Windows Defender had 3 hours to scan, it got rid of some adware/trojan and that hasn't had any effect.
Mouse: Logitech G402 (in case relevant)
Mobo: GA 970-DS3P
CPU: AMD FX 6300 3.5GHz
Ram: Corsair Vengeance 16GB 1666Hz
GPU: MSI R9 280x
Any help would be much appreciated
Gannicius
https://linustechtips.com/topic/438817-mouse-movement-cause-heavy-cpu-usage/
I don't really have anything helpful to add, but moreso a joke - are you sure it's an FX-6300, or an Intel 8088?
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
Lunix Is An Illegal Hacker Operating System
| [CPU] Intel i7 5960X (4.5GHz) | [Mobo] ASUS Rampage V E10 | [RAM] G. Skill Ripjaws 4 64GB (8x8GB) | [CPU Cooler] Custom Acrylic | [OS Drive] Samsung 970 Pro 512GB M.2 SSD | [Storage] WD Black 4TB (x2 RAID 0) | [GPU] ASUS GTX 980 (x2 stock) | [PSU] Corsair AX1200i | [Case] Corsair 900D | [Keyboard] Corsair K95 Platinum | [Mouse] Corsair Dark Core RGB | [speakers] Logitech Z906 | [Monitors] ASUS VS278Q-P (x3 27"s) |
By any chance do you have a scheme applied? Try this:
* Go to Control Panel ->Hardware and Sound -> Mouse
* Go under the pointer tab
* Under Scheme, select "Windows Default (System Scheme)", apply
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
