Build Help
+1 on Skylake.
+1 on Kraken X61.
Get an EVGA G2 psu or Corsair AX or HX. White cable sets are available for these psu. Better than using extension cables. Also better psu.
MSI GTX 980Ti 6GD5T OC might look better in the build. Has better stock performance.
I wouldn't waste any money on the extra fans. The H440 has 4 stock white bladed fans that are quiet. The X61 would add another two white bladed fans.
Unless there are particular features of the Pro version, standard Windows should do.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($359.99 @ NCIX US)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler ($114.99 @ B&H)
Motherboard: MSI Z170 Krait Gaming ATX LGA1151 Motherboard ($144.99 @ SuperBiiz)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2666 Memory ($139.38 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($89.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($85.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card ($664.98 @ Newegg)
Case: NZXT H440 (White/Black) ATX Mid Tower Case ($99.99 @ Micro Center)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($117.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($86.98 @ OutletPC)
Wireless Network Adapter: SIIG CN-WR0811-S1 802.11b/g/n PCI-Express x1 Wi-Fi Adapter ($25.36 @ Amazon)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($234.99 @ Newegg)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard ($152.69 @ Amazon)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse ($59.57 @ Amazon)
Other: Anti Static Wristband ($5.99)
Other: NZXT Lighting Kit ($9.99)
Other: G2/P2/T2 White Power Supply Cable Set (Individually Sleeved) ($89.99)
Total: $2483.85
Generated by PCPartPicker 2015-08-26 23:34 EDT-0400
Thanks so much. So the MSI 980 ti is better than the Gigabyte 980 ti?
