Cable Combs
Solved by W-L,
I have recently purchased a set of CableMod E-series cables for my EVGA Power supply. Due to my location I am not able to pick up a set of cable combs from Cablemod themselves. Are the CableMod cables compatible with both 3mm and 4mm combs or will I have to measure them?
They are a little thinner than some of the PET sleeving out there so go for the smaller 3mm combs.
