Right guys, If I was to give you £1260 (including VAT) excluding shipping + scansure to spend and build a PC from www.scan.co.uk What build would you make? Please tell me below as I'm debating like crazy with people and thought I'd get some builds from you guys, if mine are similar, means it's good :)
I'm going to be gaming on a single monitor but possibly in the future have an extra one hooked up. I'll be mostly gaming at times but also surfing the net, photoshopping and video editing (last two things are rare). I want it to be good looking yet a performance beast, lets see what you can come up with :)
I'd also preferably like a full tower case.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
https://linustechtips.com/topic/43767-help-me-build-a-pc/
It would be nice if you put some effort into deciding which parts you want.
This should also be in the New Builds and Planning section.
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-572804
What do you mean deciding what parts I want, I said, you guys go out and make a build. I just want to compare what I'm going to order to what you guys come up with..
And my bad.
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-572819
gigabyte ga-990fx-£115.22 fx8320-£122.97 hyper212 evo-£25 patriot 2x4gb black 1600mhz (£58.44) seagate 2tb-£64.98 corsair cx750w-£65 powercolor myst 7870 TLE £161.99 ARIA,co,uk sharkoon 19 case with 19pin usb3-£55ish samsung 250gb ssd-£134.99 ebuyer
a build i made for somone else, except replace the board with a crosshair 5 formula v, the card with a 7950 and the cooler with a h100 and a differnt case of your choice, maybe change the ssd to a pro version.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-572860
http://pcpartpicker.com/p/1pt43
Try that, yes please give it shot for your own. :)
Also to help you out. Go to http://www.extreme.outervision.com/psucalculatorlite.jsp to choose your PSU properly.
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-572908
To be honest a single 7970 will do the job just fine but what the heck.
Great build but I think that soon prices of 7990 will drop in UK as they did in usa recently so that might be something to consider.
As to the actual build if not overclocking enthusiast, I would grab Xeon e3-1230v3 instead of i5. That is i7 4770 without iGPU.
So... If Jesus had the gold, would he buy himself out instead of waiting 3 days for the respawn?
CPU: Phenom II x6 1045t ][ GPU: GeForce 9600GT 512mb DDR3 ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 2x4GB Kingston 1333MHz CL9 DDR3 ][ HDD: Western Digital Green 2TB ][ PSU: Chieftec 500AB A ][ Case: No-name without airflow or dust filters Budget saved for an upgrade so far: 2400PLN (600€) - Initial 2800PLN (700€) Upgraded already: CPU
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573005
This is what I've come up with, tell me what you guys think! I could add in something for an extra 20 quid but meh.
http://www.scan.co.uk/savedbasket/150aabf6a45341e9ba8ba150f52f57c8
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573023
It's ok I guess, my build would perform almost 2 times better in games and give you much higher quality audio...
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573101
i would go with a 4770k instead of a 4670k because you did say you wanted to do some videoediting
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573365
By some I mean once every 2-3 months?
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573375
well in that case a 4670k should be fine
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573475
Interesting! I did not know that! For some reason the 7990 unsettles me.
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573522
We are talking about 7990 for 700$. That makes me want it even tho I preffer nvidia.
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573573
I'm not trying to take anything away from the 7990 nor am I disregarding that that is an amazing offer. I'm just saying that something about the 7990 unsettles me.
Oh sure same here. Maybe it's terrible crossfire that has been nightmare and is just being fixed right now? Idk.
I just preffer Nvidia. Something about premium feel of GeForce. You get 780 into your hands once and you don't step back i guess. It's so freakin awesome, you can almost feel the power 780/Titan wield :D
Even if it is delusional compared to what Maxwell will bring in da house ;D
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573820
Well i hope you like cool looking and the kind Military theme build all in an m-atx rig with a beautiful Corsair 350D case with side window.
note: no monitor / mouse / keyboard / o/s included, if you need all this just say and i will have to thin down the spec.
Its also  under bugdet, just enough for some case lighing :)
Also note i selected 2 very good 140 fans for front intake and 120's for top exhaust, then the CPU cooler on the back exhaust (120) plus a SSD for O/S and a hybrid for games etc.
enjoy....
got to love Asus components
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573829
pretty good, but you spent all the budget on graphics cards :P
you got to leave some money for a cooler, case fans etc.
I realized this after I posted this and face-palmed!
Take the second 7970 off, which in reality isn't necessary for this build and this should be fine.
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573850
Also not i selected 2 very good 140 fans for front intake and 120's for top exhaust, then the CPU cooler on the back exhaust (120) plus a SSD for O/S and a hybrid for games etc.
enjoy....
This I like!
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573853
This I like!
Thank you, i don't know if the customer likes this kinda theme or wants a m-atx build so i thought i would add it just so its different, and thought about the colour scheme with the Noctua fans and Gryphon m/board then some red memory modules to give it a cool and clean small build within the spec budget.
I like your choice to.. and thanks for seeing i wasn't having a go at your thread, i was just pointing out the small things the customer might need, heck i know most people don't bother with an optical drive but i thought this is a nice all in one little work station / media / gamer for the cost the customer wanted.
I sure hopes we get some more awesome ideas to compare.
https://linustechtips.com/topic/43767-help-me-build-a-pc/#findComment-573869
