High-speed networking gear can produce some heat, but it shouldn't be anywhere near high enough to make a difference to the GPU's performance. Slam it in there and forget about it :)
https://linustechtips.com/topic/437135-network-card-temps/#findComment-5860035
Don't worry about that.
Make sure you have the enough fans and way it mounted on the case.
Something like this.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/437135-network-card-temps/#findComment-5860058
