Would this splitter work for my front two corsair case fans that came with my spec 02. http://www.amazon.com/gp/product/B002OFP6QW?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A3DUZJNIM9L5CV. It says its PWM, does that matter, because my case fans are pretty standard.
yes it will work if you have 3 pin fans it depends on the setting you have on your motherboard header which should be on DC voltage control.
https://linustechtips.com/topic/437031-case-fan-help/#findComment-5858598
