Hey
So whenever I record something with sharex, I have multiple issues. Only the last second is recorded unless I set it to record for a certain amount of time. The main problem is the second part of uploading the recording is that the upload speed starts at 1KB/s and goes down to 0B/s. Any help? Thanks! :)
https://linustechtips.com/topic/436979-help-with-sharex/
Hey
You can record things with ShareX? I've only ever used it for screenshots!
I guess I can only really help with the uploading thing - I'm guessing it does something to compress the whatever then tries to send it to a service...
What service are you trying to upload these videos? GIFs? GIFVs to?
Sig under construction.
https://linustechtips.com/topic/436979-help-with-sharex/#findComment-5857660
Uploading as a WebM for a small file. Uploading to gfycat but I don't think it matters where I upload it.
https://linustechtips.com/topic/436979-help-with-sharex/#findComment-5858105
