Need Help Finding An Inexpensive mITX Case
I've been looking at the Thermaltake Core V1 and I need to know if that would be any good, and if it would support a full sized PSU.
Is there anything you're particularly looking for in this case apart from cheapness?
And yes, it seems as though you can have a standard ATX/PS2 PSU in there as long as it's shorter than 200mm.
I'd like to suggest the Silverstone SG-13, here are a couple of videos including it:
Sig under construction.
yep, it supports a full sized psu
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
