I have 100/100 internet and I am getting that with ethernet but wireless on 5ghz im only getting 40ish and on 2.4ghz im getting 10-20ish, any ideas why and how can i fix this. My router is a Asus Black diamond Rt-N56U. How can i fix this and I prefer to keep my SSID hidden also.
https://linustechtips.com/topic/436667-slow-wifi-need-help/
Any walls in between the place you work with your WiFi device and the router?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/436667-slow-wifi-need-help/#findComment-5853419
router is in my room and mt parents laptops are located elsewhere, so yes.
Try the wifi when sitting next to the router and no other devices are wirelessly connected to it. Then introduce interference and walls.
When in doubt, re-format.
https://linustechtips.com/topic/436667-slow-wifi-need-help/#findComment-5853446
It may be the problem.
Try to use the device near the router and check the speeds.
If they are good, then it's your walls blocking the signals and speed.
https://linustechtips.com/topic/436667-slow-wifi-need-help/#findComment-5853461
I try to use my phone directly next to the router and it's kinda weird, my phone is a LG G2 , it connects then disconnects
https://linustechtips.com/topic/436667-slow-wifi-need-help/#findComment-5853491
Also check your Wifi-surrounding, maybe your access point is on the same channel as a lot of your neighbours are. That will slow down your wi-fi and decrease the range.
Try a Wifi-Analyzer app for your smartphone maybe, that should give you some information about that stuff...
https://linustechtips.com/topic/436667-slow-wifi-need-help/#findComment-5853492
I have InSSIder  and i changed my wifi channel to get the best possbile meta score.
https://linustechtips.com/topic/436667-slow-wifi-need-help/#findComment-5853507
