What are some decent tablets for $200-300?  If there are any, no real preference iOS or Android preferably not windows though but probably can't get an iPad or anything of the sort at this budget that'd be any decent versus competing android tablets, general use by the way maybe note taking in college, nothing too artsy, just web browsing, emails, ect.
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/436448-tablet-help/
Dell venue 8 pro? (Windows 8.1 8" tablet)
I've got one and it's alright, a little bit small, but for web browsing, emails, and notes it should be fine. (I've got it in the classifieds section right now if you wanna take a look at it :P)
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850630
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850633
Snip
Will be considering but tbh I forgot windows tablets are a thing because I dislike them generally but I'll be looking into these ones, if you have any android ideas feel free to suggest them though
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850652
That tablet is both Windows AND Android, and I think you can even buy it without Windows. By the way, because it's the full version of Windows, you can even use it as a laptop, if you buy a keyboard case specifially made for that device, and use a mouse with it.
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850662
Sized preference for it?
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850672
The dell venue 8 PRO is windows 8.1, the dell venue 8 is android.
But yes, it is a full version of windows, and you can buy a keyboard case for it, any bluetooth keyboard and/or mouse should work with it. (I've got a bluetooth keyboard that I can add in with mine for free)
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850676
Thanks found this out moments after my response. Sorry.
See above^
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850687
No worriee :)
My sister has it, so if you're not really sure about anything with it, you can quote, tag, or pm me, and I'll try to get an answer for you. :)
https://linustechtips.com/topic/436448-tablet-help/#findComment-5850725
