i7 4790k overclocking help
Solved by 0ld_Chicken,
you might be good then but i wouldn't be shocked if you find instability with another program our even just normal use. I've had overclocks pass 9 hours xtu and fail in cinebench 2x in a row. For me it's a constant validation process when I've got time. Whenever i think I'm good i usually add .025v or .05v since it shouldn't make much of a temp difference.so i ran intel extrema tuning stress whilst i was asleep and its still fine no crashes
