So since I will build myself a new PC at the end of the year, I'm planning to change my monitor and my keyboard. Anyone could recommend me a 21.5" ~ 23" monitor?? And I have some keyboards in mind that I could buy.
Logitech G105
CM Octane
CM Devastator
Any recommendations??
https://linustechtips.com/topic/435814-should-i-get-these/
I have a G105, it's alright, good durability, it has a few squeaky keys now, and sometimes you have to plug it in a couple times to make it work right, but generally it's an okay keyboard for membrane. But I'd go mechanical. As for monitor, I'd look at some Asus ones and look up some reviews, I always find it hard recommending monitors.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/435814-should-i-get-these/#findComment-5841718
