Hi guys,
It's been happening for a while now but randomly my screen will freeze up and if there is music or a movie.. sound in general in the background it will stop and give that really annoying feedback tone... also the comp will completely freeze up sometimes ill have to restart the PC other times it fixes itself.
When it does fix itself it says "nvidia driver failed, but has recovered"... or something similar to that. My system is fine however the GPU is a few generations old, its a gigabyte gtx460.
my question is:
Does anybody know if the latest drivers seem to have problems with this card, or could it just be my card dying, or something else completely.
Thanks for taking the time to read this.
DB
SYSTEM:
gigabyte z68-ud3r-b3 (before pcie 3.0)
2500k (4.5ghz)
hyper 212
Samsung 840 ssd
gigabyte gtx460
silverstone ST75F-P 750W
https://linustechtips.com/topic/43517-nvidia-driver-problem-maybe/
Is your graphics card oced? It might have degraded over time, as it is quite old and may not be stable at that clock any more...
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
The latest drivers seem to be having problems in general. It very well could be a driver related problem. But are there any overclocks done on this video card?
Driver version?
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
sorry i should have mentioned. The card has never been overclocked and current driver GeForce 320.49
yeah I just got a 770 today with that driver runs fine for me did you just install it ?
PRIMARY NVIDIA PC
SECONDARY RADEON PC
no i just update the drivers automatically when ever they are released. its been doing this ever since the released the 700 series. not sure if there is correlation there... but its just a little annoying. the card still plays games fine but should i consider upgrading to solve these problems? and which card would you suggest to upgrade to. no  preference for amd or nvidia. budget around $300
Well you can get a 7970 for 300 ATM but i would just do a clean install before thinking of buying new hardware.
PRIMARY NVIDIA PC
SECONDARY RADEON PC
Rather than jumping the gun and upgrading now, just wait for AMD's new lineup of cards coming in October, they should drastically improve performance/price because of the new fabrication node.
In the mean time, revert back to the last stable Nvidia driver version, this is most likely caused by the new drivers for the 700 series, they've been causing serious issues and even damaging cards rendering them completely useless.
*sigh* clean installs are annoying. alright. I suppose ill just do that, hopefully it will fix itself. and @ TechFan@ic that sounds like a good idea.
I might wait and maybe get a new card when BF4 comes out.
Thanks for your help forum members :)
Very well could be a driver problem, but I use the latest drivers (326.41) and have zero problems with them. Of course, YMMV. I do find these drivers way better than the last two they put out.
Clean installs don't have to be annoying. Once you do it enough, it only takes a few minutes to delete all the Nvidia folders and registry entries. This way, at least you know you can eliminate a poor driver install out of the variable.
