Max Haswell Voltage?(4670k)
Solved by Samdb,
The maximum voltage for a CPU is 1.5V, however if you go above 90C you will begin to damage your processor, under 100% load you will want to keep it under 90C as mentioned before. You will not be able to claim any damage on the warranty as you have caused the damage yourself.
Sam,
Intel Response Squad member
Macaw ·
Posted in Console Gaming3 -
3
Shahrad ·
Posted in LTT Releases2 -
4
frozensun ·
Posted in Graphics Cards7 -
kisserik93 ·
Posted in Peripherals11 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory14 -
3
