looking for a very specific case, please help
hi y'all
im looking for a case that allows an aio cpu cooler to be mounted (as exhaust) in the top. it needs to be black/grey
the specific part is: it has to be a bit like the nzxt s340 (a flat and very 'stealthy' look)
so, not so outstanding/striking/showy
If you're formally an engineer, avoid responsibility. That's what senior engineers get paid for.
https://linustechtips.com/topic/434267-looking-for-a-very-specific-case-please-help/
well... if you like the s340 then go for it,
you can try Corsair Vengence C70
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
forgot to mention the aio is a 240
ok, ive been very unclear
a case that isn't very striking, black/grey, top mounted 240 aio, enough intakes for possitive presure, atx
H440
R5
Define s
Enthoo luxe
Evolv Atx
