I started overclocking my gpu, and everything is fine, i run some bench marks to compare to before i overclocked, and they were much worse than before. Please help me i do NOT want $350 to go to waste. I have an EVGA gtx 970, and i was using MSI Afterburner.
CPU:Intel i5 4690k GPU:EVGA GTX 970 SSC Motherboard:MSI Z97 G45 RAM:Kingston HyperX Fury 8GB PSU:Corsair CX600M SSD:Crucial MX100 256GB HDD:Seagate 3TB Case:Corsair SPEC-02
https://linustechtips.com/topic/434172-overclocking-problem/
Do you think you could post some pictures?  Is it a reference or non-reference card?
https://linustechtips.com/topic/434172-overclocking-problem/#findComment-5819121
it is non-reference, and it is also the super super clocked version if that means anything.
https://linustechtips.com/topic/434172-overclocking-problem/#findComment-5819142
A few more details would be nice like before and after benchmarks and your overclocking settings.
https://linustechtips.com/topic/434172-overclocking-problem/#findComment-5819239
i used msi kombustor for the benchmarks and stress tests.
Before the overclock, Furmark had 2274 points and 37 fps. Physx 3 fluids had 4956 points and 82fps. Lakes of titan had 38836points and 647 fps.
i finalized the overclock at a boost of +123 for core clock and +124 for the memory clock.
After the overclock, Furmark had 2585 points and 43 fps. Physx 3 fluids had 2277 points and 37fps. lakes of titan had 18982 points, and 316 fps.
And no, i didnt try to reinstall the drivers.
https://linustechtips.com/topic/434172-overclocking-problem/#findComment-5819787
https://linustechtips.com/topic/434172-overclocking-problem/#findComment-5819791
