My iPad Mini(1st Gen) has a small issue
It is running at iOS 8.4.1 and was never jailbroken
When I plug any Lightning Charger official or 3rd party it shows "not charging" even though it charges
Also after 18 months of use  after purchase it started charging at an awfully slow rate (about 4-5 hours to be full)
And the it lasts me about 1 and a half hour
Should I be concerned
I don't intend to replace it till 2017
bought it on February 2013 (32GB LTE)
MacBook Pro 13" Mid 2012 w/Core i5 3210M and glorious HD 4000 Graphics
https://linustechtips.com/topic/433957-ipad-mini-charging-issue/
SNIP)
Probably the battery wearing out, take it into store and they can replace the battery for you (at cost)
https://linustechtips.com/topic/433957-ipad-mini-charging-issue/#findComment-5815803
Well duh.
https://linustechtips.com/topic/433957-ipad-mini-charging-issue/#findComment-5815817
