Help with OC Stability
Solved by Imakuni,
You should be perfectly fine. Not only this is a mild OC, temps are also good enough. If passed 1,5h of Aida, it's likely to be good.
But if you'd like to test it further, grab yourself Folding Home, Boinc, or prime95 (in GIMPS mode) and just let them run for a week straight. If it passes, I'm pretty sure your OC is rock solid. It'll also help out the community a little (actually, a lot, the 5930k is such a strong CPU...). You can keep using your PC as normal, just let the thing run on the background.
