How to keep GPU overclock settings?
Go to solution Solved by W-L,
So I overclocked my gpu, apply voltage, core clock, mem... and everything is stable. But I think the gpu go back to its original settings when I restart my pc. How do I keep the gpu at the overclock settings.
If your using MSI afterburner or such there is usually an option that allows you to apply the overclock during startup.
Thanks I remember there was someway to do it. But most tutorial don't mention it. I haven't overclock in so long I kinda forgot
when you load up Afterburner, you should see a button you can check mark right on the interface, underneath Core Clock, Memory and all that. I wouldn't suggest doing that though incase something goes wrong.
CPU: Core i7 4790k - CPU Cooler: Thermaltake Water 3.0 Ultimate - GPU: Asus GTX 980Ti - Motherboard: MSI Z87-GD65 Gaming - Ram: 20GB Corsair Vengeance DDR3 @ 1600MHz - Storage: ADATA 256GB SSD, Samsung 840 Evo 1TB SSD & WD 1TB HDD 7200RPM - PSU: NZXT Hale90 V2 1000W Gold+ - Case: Phantek Enthoo Primo Black Exterior/White Interior - Display: Samsung 29" Curved Ultra Wide - Keyboard & Mouse: Razer Blackwidow Ultimate & Roccat Tyon - Sound: Razer Kraken USB Headphones, Blue Yeti, Logitech z313 Speakers
