Posted August 18, 2015 Hi I am just about to start my second pc build which will be used for gaming asmy other one is a hackintosh. I need help with GPUs and which will be best for what I will play. I aim to play games like counterstrike and Fallout. I have the budget for 2 Nvidia GTX titan 's and was wondering if there was any Better solutions for my pc. Link to comment https://linustechtips.com/topic/432554-gpu-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2015 Hi I am just about to start my second pc build which will be used for gaming asmy other one is a hackintosh. I need help with GPUs and which will be best for what I will play. I aim to play games like counterstrike and Fallout. I have the budget for 2 Nvidia GTX titan 's and was wondering if there was any Better solutions for my pc. Resolution? Link to comment https://linustechtips.com/topic/432554-gpu-help/#findComment-5798633 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2015 Resolution? Other parts? Link to comment https://linustechtips.com/topic/432554-gpu-help/#findComment-5798639 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 18, 2015 "I have the budget for 2 Nvidia GTX titan 's" one of titan is already overpowered for Counter strike global offensive (you probs talking about this one right?) and which fallout are you looking to play? If it is 3 one titan is also enough and overpowered.. In the end it come downs to what resolution? Magical Pineapples
