Will reading from a USB drive wear my SSD?
Go to solution Solved by Bubblez,
Does reading from a USB drive write to a computer's storage? I recently purchased a SSD for my laptop and an external hard drive to put movies on. If I watch movies from my external hard drive will data be temporarily stored on/written to my SSD and in turn wear it down? Thanks in advance!
Kind of. There will always be bits and pieces of a file transferred to your PC, depending on the programs you use... some programs create thumb nails in a temp folder... and while you could delete the temp folder manually, nothing is truly deleted until it gets written over with new information. The full file wont be transfered to your computer unless you save it or move/copy it to your computer. This isn't something you should be worried about, a typical person wont find this information... And as VirtualR3ality has pointed out, this small amounts of information wont do a thing to your SSD at all.
Rest assured, your wife will never come across your porn -- Sorry, I mean 'movies' -- on your computer if your external hard drive isn't plugged in.
Here is some information I found.
https://superuser.com/questions/176304/does-using-an-external-disk-drive-or-even-a-usb-key-leave-a-trace-on-a-compute
It won't unless you choose to copy the data to the SSD. Otherwise you're just reading from the external HDD.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
Jason you really shouldn't worry about wearing out your SSD, if anything it will last just as long if not longer under normal loads then a mechanical HDD on a laptop.
CPU: i7 5820K @ 4.00GHz Mobo: ASUS X99-DELUXE LGA 2011-v3RAM: Corsair LPX 64GB Quad-Channel DDR4 @ 2400MHzGPU: GTX 970 x2 SLI | Storage: 250 GB AMD SSD x 4 Raid 0
Modern SSDs last for decades in the hands of a normal user but before that you will swap them. Also reading from an external drive has nothing to do with your internal drive.
| CPU: Intel Core i5 8400 | Motherboard: MSI Z370 PC Pro | CPU Cooler: CM Hyper 212 PLUS | GPU: Zotac GeForce GTX 1070 AMP! Edition | RAM: G.Skill Aegis 16GB DDR4 2400 MHz | PSU: Corsair VS650 | SSD: SanDisk SSD Plus 120GB | HDD: Seagate Barracuda 2TB | Monitor: Dell S2240L | OS: Windows 10 Pro x64 |
