Hey guys! This is going to be my first build, and im checking here if anyone knows if all the parts are compatible  :huh:  So the parts list.
PARTS:
CPU: Intel i5 4690K, will be Overclocked!
MOBO: Gigabyte GA-Z97N-WIFI
GPU: XFX Radeon R9 390X (5mm longer t
RAM: Crucial Ballistix (Might be Sport) 16GB 1600MHz CL9
PSU: Corsair RM650han the Official maximum GPU length in the case)(295mm)
CASE: Corsair Graphite 380T
CPU Cooler: Cooler Master Nepton 240M
CASEPAINT: PlastiDip Blaze Green                                 (Save the Nature, go Green, buys AMD  B) )
OS: Windows 10
SSD: Samsung 850 EVO 250GB
HDD: WD Black 1TB
FAN: NZXT FZ-200 200mm LED GREEN
Anyone got any thoughts? :P  And opinions about them being compatible
https://linustechtips.com/topic/431936-first-build/
Use pcpartpicker.com
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/431936-first-build/#findComment-5791002
Going with what the person above said, using pcpartpicker will help you with a lot of the little things that might come about incompatible.  All in all though it looks like you've done a fair bit of research.  Have fun with the plastidip I could never get that stuff to look right for myself.
"You should look up common sense and add it to your vocabulary." - dougdangger 2015
https://linustechtips.com/topic/431936-first-build/#findComment-5791080
PARTS:
OS: Windows 10
HDD: WD Black 1TB
click the link on my signature.
you dont need 16gb of ram for gaming, 8gb is enough. I would go with a SeaSonic or EVGA PSU.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/431936-first-build/#findComment-5791091
Link at my Profile
pcpartpicker.com
wow hard.
https://linustechtips.com/topic/431936-first-build/#findComment-5818627
Im getting the ram for 730 NOK, when it costs 860 NOK at it's cheapest, but over 1000 NOK at the well known sites, and its 200 NOK diffrence, so il'l go with it, same with the PSU, im buying it from a friend, so i get it cheap  :P If i found the right "link" you talked about, a 960 isn't enough...
https://linustechtips.com/topic/431936-first-build/#findComment-5818642
It's ordered, so thats my new "System", so a pcpartpicker.com/xxxxxx link will be in my profile  ;)  And thanks, i hope i get it right to  :P
https://linustechtips.com/topic/431936-first-build/#findComment-5818667
