My components:
i5 4690k
r9 390
thermaltake macho cooler
1x intake 1x exhaust
Evga supernova 750 B2
Fractal design define r4
Its silent except from there noise until I put the case fan on full speed which hides the noise but on silence you can hear it while its on I cant pinpoint the noise but it seems its the Gpu
https://linustechtips.com/topic/431525-buzzing-noise-from-case/
Could be your power supply :P
#RIPTopGear  This is the best thread ever: http://linustechtips.com/main/topic/53190-i-can-not-get-hard/ " French meetings are just people sitting in a semi-circle shouting at each other" -Dom Jolly  :lol:
My rig:
   CPU: Pentium G3258 @ 4.5GHz GPU: GTX 760 reference | PSU: Corsair RM750 Cooler: Cooler Master Seidon 120V | Motherboard: Gigabyte B85M D3H | Case: NZXT S340 White | RAM: 8GB EVO Potenza @ 1600MHz Storage: 3TB Seagate HDD, 60GB OCZ SSD, 620GB Toshiba HDD | Mouse: Steelseries Rival @1000 CPi |  OS: Windows 10 Pro Phone: iPhone 6S 16GB
http://linustechtips.com/main/topic/439354-why-nvidia/
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5785422
Its the desk viberating because of the pc man its really annoying​
What kind of fans you got in your system?
My rig:
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5785481
Checking loose fans.
CPU:AMD Ryzen 5 5600 3.5 GHz Processor | CPU Air Cooler:Thermalright Assassin X 120 Refined SE | Motherboard:MSI B450M GAMING PLUS MATX AM4
Memory:G.Skill Ripjaws V Series 32GB (2x16GB)  DDR4-3200 | GPU:PowerColor Fighter Radeon RX 7600 8 GB Video Card
Storage #1:Silicon Power A55 512GB SSD (OS driver) | Storage #2: Silicon Power A60 1TB M.2-2280 PCIe 3.0 X4 NVMe (Anything else)
Case:Cooler Master MasterBox Q300L | Case Fan: 3x Thermalright TL-C12C (2x intake fans, 1x exhaust fan)
Power Supply:Corsair CXM (2015) 450W Bronze 80 Plus |OS:MS Windows10 (64-bit) | Monitor: ASUS VG275 27” 1080p 75 Hz FreeSync
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5785482
stupid question is glass a good material to put the pc on to prevent viberation?
Best to not have on glass especially if it's a super heavy PC, if it's vibrating the desk then check your fans, and drives, mount them on rubber isolators or the entire case on some simmer isolator. The vibrations are basically the same harmonics as your desk amplifying the noise, I has a similar problem when it would cause extra noise since the cabinet was amplifying it making it hum.
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5785586
would this solve the problem
http://www.quietpc.com/acoustifeet
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5785598
Those would help a little but it's best to isolate at the source with anti-vibration hard drive mount and fans or have quieter components.
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5785633
we have anti-vibration mounts on the hard drive and properly screwed in, the desk is amplifing the viberation im suspecting the fans I just plugged in the stock fractal design fans did I need to screw them?
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786520
If they are clipped in securely It should be no problem, it's hard to say but isolating it from the desk or say the entire hard drive cage can help. I found my hard drive was the problem so I mounted the drive on a piece of plexi and a thick foam blocks which stopped a almost all vibrations.
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786575
Trying to think of a solution because my hard drives are fitted with anti-viberation mounts, when i lift the case its gone completely
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786622
vibration source can only be from a moving thing so a fan or disk platter but the thing making the noise could be anything lose in the case.
open the case and start holding stuff till you figure out what is making the noise and see if you can secure it.
if you just want to isolate it from the desk , speaker stand foam / dense foam would work but you are best finding the cause of the issue and solving that rather than trying to mask it.
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786659
could a bottom mounted psu cause vibration
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786705
The easiest would be to move it to another surface but I find most of those rubber isolators not that amazing. If you have a removal drive cage you could mount the entire drive cage with soft rubber isolators.
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786734
i only have anti viberation on the hard drive and not on the ssd, would putting these on the hard drive cages stop the viberation?
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786741
It would be more like a modded mounting to have the entire cage isolated from the case, another option is something like this suspending the hard drives in the 5.25" bay.
http://www.silentpcreview.com/article8-page2.html
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786787
should I unplug the hard drive and see if the viberation stops what happens?
https://linustechtips.com/topic/431525-buzzing-noise-from-case/#findComment-5786799
