Look at the bottom right of your desktop, you should see a task tray. Left click the speaker icon, then select "volume mixer" or "mixer" and manually adjust the skype volume and game volume to your liking.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/430675-skype-audio/#findComment-5774855
if your using windows 10 right click and select volume mixer
IDK y but skype isnt listed there, is there a way to make it apear?
https://linustechtips.com/topic/430675-skype-audio/#findComment-5774896
Make sure then you're on the right audio device. Right click that icon and go to playback devices, then find the device you're using for audio and set it to default for communications by right clicking and selecting "Set as default communication device"
Then if skype stops playing sound, you'll need to go to skype and click on the options setting, then select the correct playback device to use.
After all that you should be able to see all the different sources of sound in the volume mixer.
https://linustechtips.com/topic/430675-skype-audio/#findComment-5774906
