Should I overclock my 660ti? if so what's the best way so see if its stable, I have the asus Direct CU2 660Ti so its got decent cooling , max temps stock are 68 degrees
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/
68 degrees? What case do you have?
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561759
Aerocool sixth sense mid tower
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561774
It's nothing to worry about, but those stocks seem a little high to me.  Your case has proper airflow?
Might want to think about reapplying the TIM to your card.
i5-3570K @4.2ghz | Gigabyte Z77-DS3H | 16GB G. Skill Ripjaw 1600mhz 9-9-9-24 (2x8GB) | 120GB Vertex 3/640GB WD 7200RPM | AMD HD7950 @ 1025mhz | 600W Corsair CS600 | Hyper 212 CPU Cooler | 5x 120mm fans 79cfm | Ultra Defender Case
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561852
What kind of cooling do you have in that case currently?
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561855
yea i have decent cooling , my cpu is idle at 28 degrees with max temp of 70 degrees , and thats overclocked and watercooled , i have 6 hard drives all cooled properly with a front intake , i have a top intake too and my water cooler as my exhaust also my psu is an intake
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561871
Temps are certainly acceptable. Airflow seems acceptable - what do your fans run at on your video card when you're doing something a little demanding?
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561881
40-60 percent :D i thorght 68 degrees max i have ever seen , is decent for a nvidia card , the card idles around 35 degrees
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561888
You'll certainly be able to overclock a bit, but for some reason, my temps are way better than yours. When my GPU is stressed out(I have two 660 Ti's) when folding proteins, the card stops at around 55 degrees C with 40% fan speeds. It's also overclocked past 1.2GHz, and voltage has been increased.
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561899
hmm maybe if i put some artic silver 5 on my gpu it might shead some heat?
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561907
You might want to try that.
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561914
ill do it after ive finished backing up files , then ill get back and tell you the temps :D
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561924
Okay.
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-561943
Okay.
I cleaned the gpu which was a pain because the old thermal compound had gone hard -.- , i then applied some arctic silver 5 , and booted up, there's about a 2 degree difference :( i was expecting more tbh
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-562369
Even under stressing load?
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-562381
its the same as the old thermal paste under load for 10mins
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-562389
the arctic silver 5 does take up to 216 hours to cure , for best results ,
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-562422
Okay.
https://linustechtips.com/topic/43066-help-overclocking-my-660ti/#findComment-562515
