Hello gys so some of you might have seen my post about an hour ago and now i have it all figured out...i think.
Anyway i need a water loop in the 900d that can cool a 5930k and 3 evga superclocked titan x's call me crazy but i have the money i been saving up for this my hole life (well more like the last 2 years but it feels like it). And i thought you guys might have a good order for the loop to go in. And screw budget if i don't have the money well i'll save up a month or two. I want to have as much radiators as possible! Oh and please no comments saying that i am wasting money i know but hey it is a dream and you shall chase your dreams!
https://linustechtips.com/topic/428678-900d-water-loop/
Blocks: Swiftech for CPU, and EK for GPU
Tubing: PrimoChill flexible (DO NOT HARDLINE)
Coolant: Distilled Water
Pump: Anything small and powerful by Swiftech or XSPC
Reservoir: Phobya anything
Rads: 480mm XSPC bottom, and 360mm XSPC top
Direction of loop:
Res-Pump-480mm-GPU3-GPU2-GPU1-360mm-CPU-Res
Actually i thought i can have 2 reservoirs one for the cpu and one for the gpu's but why not hardline it looks soooooo good and the coolant is going to be some ekwb-ekoolant blue
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750345
Two EVGA GTX 980 TI Hybrids will outperform your 3x SLI Titan X setup as most of your VRAM will not be utilized and the 980 TI has a faster core clock.
Take a look at this article how a SINGLE 980 TI trades blows with the Titan X in many games. http://www.gamersnexus.net/hwreviews/1983-evga-gtx-980-ti-hybrid-review-and-benchmarks
I know I didn't answer your question, but I can truly not see any reason for 3x Titans at $1,000 a piece when you can use two 980 TI's at $760 a piece and they come with their own AIO water cooler.
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750347
1: I wont have to upgrade in about 3 years
2: aio water cooling is not as good as custom
3: no they don't have a faster core than these evga superclocked versions edit: yes actually they do sorry
4: I have already bought them so it is a bit too late.
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750398
http://linustechtips.com/main/topic/44526-august-10th-overkill-buyers-guide-where-to-buy-components/
You could use that info and only change the blocks to fit your parts.
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750454
1. Debatable, but I won't linger on it.
2. Agreed, but the AIO cooler on the Hybrid is designed to keep it at 56C under load which is the lowest I have ever seen for a water cooled GPU. There is plenty of room to OC.
3. All good.
4. You bought them more than a month ago? I suppose there is an option to resell, but if you're stuck you're stuck.
I can't help you with custom water builds, I have no experience.
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750473
you can start with hardline if you wish, just know that it is harder to do then soft tubing.  I started with hardline and didn't have much trouble with it.  You can go with 2 reservoirs though its not necessary, unless you planning on doing two custom loops in the same case using 2 reservoirs is purely for looks, no matter what you coolant is going to reach the same max temp only difference is it might take slightly longer.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750488
Allright thanks for the help i will probably put up a post tomorrow about wich parts i will be using!
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750550
May be a detail but what fans you plan on using?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5750668
Right fans can make a big difference too, make sure you get some good static pressure fans for the rads.
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5751391
If you're using 120mm fans only, i recomend EK Vardars, they are expensive but...(3 titan x :P) and you can get them from most watercooling suppliers, they are also really fucking good, and come in grey, black and white. If you are using both 120mm and 140mm, Fractal design Venturis are great, Noctua has to mentioned according to the terms of use of LTT (They are excellent tho, not the best for color matching) If you want pretty but good performing fans, Bitfenix Specter Pros are very good at low RPMs. Also if you are puting a rad or two on the basement, i recomend Silverstone AP123s, very quiet and they channel airflow, making it easier to mantain good flow down there (specially beneficial if you put 2 rads in the basement) Gentle Typhoons are great but they are only 120mm and kinda hard to find.
Mind if I add, get a D5 pump, not a DDC, they are better, just, better.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5751475
3. All good.
56 is pretty toasty for a watercooled GPU, although compared to a stock cooler that's great.
Most custom loops will keep a GPU at around 40-50.  (usually around 40 though, 50 being the toasty side) My 980 in my custom loop doesn't break 33 with 23c ambient. (Although my loop is a bad example as my liquid doesn't ever get any hotter than ambient temperature)
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5751700
Agreed D5's are great, strong and silent doesn't get any better then that.  Get the Vario version it has a switch that you can turn to set the pump between 5 different speeds.
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5752041
SP120 quiet editions are good. +1 Skate048.
I know i can't even hear them now and i have 7 of them running at max speed!
No you know what i just found out that if i want petg tubing and fittings for it it is going to cost me $1768 just for shipping fuck that i'm giving up on my fucking dreams and fuck sweden!!!!!
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5754570
I'd just do hard tubing,  order to link everything up does not matter just go with what looks better.  Since you said you are not worried about price,  don't bend the tubes use 90 degree fittings.  It's what I did for my build. It's my 1st water pc and not bending the tubes and using fittings made it easy
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5754875
Yes but i do care  about the price a little little bit  because i am ot going to pay nearly 2000 dollars in shipment but i guess i can go with soft tubing but that is just ugly but it will have to do since i live in a horrible place for a pc entushiast (i have no idea how you spell that).
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5754897
Hello again guys so i had some problems but i think i solved them so now i have created a new loop idea for just under $1000. There is going to be 2 different loops one for the cpu and one for the gpu's.
Here is the order the loops are gonna be going in. And please no more comments saying it is a waste of money if it was only a gaming rig then yes but it is going to be used for work aswell!
Cpu  loop order: Reservoir-pump-cpu-480 radiator-reservoir
Gpu loop order: Reservoir-pump-480 radiator-gpu's-reservoir
Please tell me what you think and give me some suggestions here is the system along with the watercooling parts: http://pcpartpicker.com/p/3Zjbgs
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5755540
$7000 well spent !
Bro i know it is a bit of a waste of money but it is not going to be a gaming rig only god no i'm going to be 3d printing and some heavy work for my job and i have been saving for about 2 years for this and around $3000 is sponsored from my job. I know i have the coolest boss ever!
Do you really need 3 titan x? Beacuse its probably not worth it unless you are doing some unusual stuff.
I am going to be 3d printing and some other heavy work and of course gaming!
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5755597
Its still overkill and that 3ed card bit if thats what you want to do by all means go for it. I would choose a better case for it though I would get like a Caselabs Sma8 or and S8S
https://linustechtips.com/topic/428678-900d-water-loop/#findComment-5755656
