Hey guys, I was just wondering how you guys put your LED strips in your cases. I often hear people pasting their LED strips above the window of the side panel. How do you run the cables for it in such a way that it hides away from sight?
~~~SnapDragon~~~
| CPU: AMD Ryzen 9 9950X3D | CPU Cooler: Gigabyte Aorus Waterforce X II 360mm |RAM: 2x32GB G.Skill Trident Z5 Neo RGB 6000MHz | Mobo: Gigabyte X870E Aorus Xtreme X3D AI Top  | Storage: Samsung 9100 Pro 4TB + Samsung 990 Pro 4TB + Samsung 870 Evo 4TB + Samsung 870 Evo 2TB | Graphics Card: Gigabyte RTX 5090 Aorus Master 32G | Case: Lian Li Lancool 216 | PSU: Seasonic Vertex GX-1200 |
https://linustechtips.com/topic/428377-case-led-layout/
I put my LEDs on the sides and top.
Project: Veronica
  • CPU                  Intel Core i5 4690K @ 4GHz
  • Motherboard   ASUS Z97 Pro Gamer
  • RAM                 Crucial Ballistix Elite 16GB (4x4GB) 1866MHz
  • GPU                 NVIDIA GeForce GTX 1070 Founders Edition
  • Case                NZXT S340 Red/Black Edition
  • Boot                Samsung 850 Evo 256GB
  • Storage           2 x 1TB Western Digital Blue Hard Drives
  • PSU                 Corsair CX600M 80 PLUS Bronze
https://linustechtips.com/topic/428377-case-led-layout/#findComment-5746161
The best usually is on the top and bottom but as long as it doesn't reflect off of surfaces or you have direct line of sight of the LED's itself since they are very bright. Cables aren't too bad if they are on the chassis since you can sleeve or tuck them away with cable clips, on the side panels they can be a little trouble since you have to unplug before removing the panel.
https://linustechtips.com/topic/428377-case-led-layout/#findComment-5746165
Yeah I currently have the same setup too but if I were to paste them on the side window instead, will it illuminate the innards more than if I were to place it at the top and bottom?
~~~SnapDragon~~~
https://linustechtips.com/topic/428377-case-led-layout/#findComment-5746169
I just have one strip on the top. It has a cable running out the water loop holes and out to the wall.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/428377-case-led-layout/#findComment-5746171
It should be brighter if placed on the side panel. But if anything is in the way (Cables, etc), it will drop the brightness a lot.
https://linustechtips.com/topic/428377-case-led-layout/#findComment-5746190
