Is there a site like PCPartPicker but for water cooling?
Solved by Chiobe,
When it comes to pc parts, so do they normally list what can and cant be used with said part, which is why its easy to keep a database of it.
But when it comes to water cooling, so is there no such info beyond basic things like size (10mm fitting wont work with 13mm tubing and such).
I mean, not only would you need to keep an database of every part that can be water cooled, but you also need a complet list of every water cooling part out there and how they fit together. Dont think even big sites that sells water cooling part has that kind of info. Heck, even companys would have a hard time knowing how there stuff works with other companys stuff.
