I don't know if many of you emulate and use netplay. I got dolphin v 6554 and have all the settings correct. I have tried playing with ssbm. When i try to connect, it fails to connect and when i host, there is no code to give. It worked before i upgraded to win 10 so that might have something to do with it
https://linustechtips.com/topic/427567-help-with-dolphin-netplay/
What site are you using, if any? Anther's Ladder?
Also, don't forget to follow your topics :) @Elclid
this doesn't answer my question
I'm aware of this, but I can't help based off the detail you gave. On Anther's there are very strict guidelines on settings to use so I would've suggested to refer to those and ensure you have everything configured correctly.
