So i am making a new build and i will be using the Corsair 280mm H110i GTX
The case i am getting does support Push pull config for a 280mm radiator on top. The case is the corsair 780T
So is it worth buying another two 140mm fans and putting them in to a push pull config or just leave it as it comes with the two fans on one side?? Thank you :)
Did not know what section the post should go in, Air cooling or water
if you want the to run much quieter but still have the cooling performance of 2 high speed ones, yes
if you want to run all 4 at max speed for ultimate performance, yes
if you dont want to have o deal with the cables, screws,  and more point of failure, dont
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
Maybe Push/Pull is unnecesary, but replacing the fans isn't. I'm not much of a silent freak, i actually prefer some noise from my PC (White noise helps me concentrate) but the Corsair stock fans on my H105 were so, so, so fucking loud, so, replace those fans if silence is a concerne at all for you. Linus did an extremely similar build in which he placed the H110 on the front and replaced the fans with bitfenix specter pros. Those are decent fans and look damn good, but Noctua NF-P14s redux, NF-A14, Fractal design Venturis, Phanteks PH-F140MP, Noiseblocker PK-2/3, Cougar Vortex, Silverstone AP141 and Thermaltake Ring 14 are all good options. Just pick one (not necesarily within this options, i don't know every good rad fan in the market :P) based on what noise levels you tolerate, how low RPMs are you comfortable, looks, and of course, budget.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
