Hi.
I was wondering if anyone could make me a simple cpu loop for 200$.
I am using the I7 5960x on the asus rampage v extreme inside a corsair 780T.
I want to use both drive bays so I can unfortunately not use a 360mm radiator.
When making this loop I would like you to make the loop using this site: http://www.techbay.no/
I apoligize that it is in norwegain. The mx price I can pay on that site is 2000 Nok.
Thank you in advance!
https://linustechtips.com/topic/427362-need-help-making-a-simple-cpu-loop-for-200/
At that pricepoint an AIO loop, for a decent watercooling kit from EKWB they usually start at $300:
https://shop.ekwb.com/ek-kit-x240
In norway on a site I found it went for 255 dollars but that was the L240. what is the difference between these two? Should I just go with the Swiftech H240X or h110i?
Mainly the tubing is a black EPDM tubing not clear, rad is small being the 240mm kit and the waterblock is one step down from the EVO series.
I would suggest to go with a custom kit if you plan to expand the loop further down the line and include the GPU into the loop.
I am going to sound stupid for asking but what is a custom kit?
The one linked earlier from EKWB you need to assemble and fill it with fluid and maintenance the loop, same with the L240.
