So I got an older PC that hasn't been used for a long time.. and now it doesn't power on. The Mobo LED lights up, but I can't get it to start.
Tried shorting the power pins but didn't do anything (PWRSW on the screenshot) So I suspect it's the PSU?
I've also tried removing individual parts. I don't have a tester unfortunately. Is there a way to tell for sure that it's a faulty PSU?
Thanks
post-124480-0-05871400-1439148121_thumb.
post-124480-0-54002400-1439148122_thumb.
https://linustechtips.com/topic/426792-old-pc-doesnt-power-on/
Do a BIOS reset, Replace the BIOS battery.
It may work.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/426792-old-pc-doesnt-power-on/#findComment-5725466
It may work.
This and you may want to put a cooler on there :P
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/426792-old-pc-doesnt-power-on/#findComment-5725505
thanks for the suggestions.
I haven't noticed the missing capacitor before.
Ye, forgot to mention that... I did try to remove the battery / reset the BIOS.
And the cooler was of course on, I was only checking the CPU and took the picture, so the lighting is sufficient.
Will check the connectors.
https://linustechtips.com/topic/426792-old-pc-doesnt-power-on/#findComment-5725794
and it looks like hes missing a capacitor ??
just over the asus heatsink
64221_top.jpgNo, It comes like that.
Try it with one stick RAM and check.
You could clean your mobo.
Take out all the parts and re-assemble it.
Then check.
https://linustechtips.com/topic/426792-old-pc-doesnt-power-on/#findComment-5731140
Thanks
#1 Does the CPU fan spin? If not, it's your psu, mobo
#2 Do the hard drives spin? If not, it's your psu, mobo
#3 By start, do you mean boot into an os? Maybe your HDD is bad.
#4 Do you have a spare gpu that you can try to use to see if you get a video output? The onboard gpu might be bad.
Hope this helps.
https://linustechtips.com/topic/426792-old-pc-doesnt-power-on/#findComment-5732149
