2015 First PC Build
h board is simple, budget, boards are easily swapped like i said... non K cpus are not
if u put alot of time in cable management u can just unplug ur 24pin and ur case connectors + the 4/8pin screw out the mobo > screw in the new mobo > place connectors again and ur done... easy setup
and then again if he would take 1hour on it instead of 10mins its still 1000x better then going with a non k cpu, the non k cpu will be a total waste for future, the h board can just be sold or reused for a mediacenter or somthing
( or just as spare part incase u got a problem with ur proper board and need to rma )
u should make a poll really... NON K CPU OR K CPU ... check results
gl ul need it
He said he wants a PC to play games. People said get an i5, now your telling him he needs to buy a cpu that can't even be utilized by the setup everyone was saying is good because he should upgrade the mother board later. He is on a budget a k series isn't a budget item. What if this PC isn't going to be upgraded and he just wants something to play games on now.
Because all boards have the exact same layouts
@pemberton_h Also you should look at the 290X they are about the same price and perform slightly better then the 390
