I'm really confused about this stuff. My understanding is that H.264 is a video codec while X264 is a program to encode the H.264 video? If H.264 is a video codec, how come you don't see files named .H264?
Also, I thought a codec stood for compressor-decompresser. So surely H.264 doesn't need a program to encode it (X264) because H.264 is a compressor in itself..............................................
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/426532-difference-between-x264-and-h264/
Huh? Isn't H.264 the compression method? Idk much about this stuff myself so I'll be hanging around here
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
h.264 a standard codec for vedeo compression (it's video only)
EDIT: my bad x.264 is the library
A .mp4 is a container that is made up of a h.264 and a .aac file for video and audio.
That's why you don't see any .h264 files around
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
What do you mean by library?
