http://pcpartpicker.com/p/Ms2ZmG Is my build I currently have. I will be doing video editing on it which will be fairly CPU intensive and kind of GPU intensive although not as much. The case comes with one 200mm fan in the front and a 140mm fan in the rear. The fans it comes with are okay but nothing special. I was wondering though should I get a 140mm top fan and 140mm bottom fan for underneath the power supply? Also, which is more important, get two extra fans or get an extra fan for my Noctua cpu cooler?
Thanks
https://linustechtips.com/topic/426243-fan-help-with-new-build/
It's also a full-tower case which is pretty big and allows air to move around more easily. The included 200mm and 140mm fans are pretty large, which means they can move more air out at a slower speed than smaller ones. Considering your system build, you should be fine.
https://linustechtips.com/topic/426243-fan-help-with-new-build/#findComment-5719389
