Does installing additional fans decrease temperatures ?
Yes, it should, how much? that depends on case by case.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
It depends on how good the fans are and how decent the airflow within the case is, I'd Deffo get the fan if it's that cheap.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
How are your temps right now?
If your temps are high and total airflow is bad then adding a fan could make a significant improvement.
But if airflow is already good and temps are reasonable then you might not see much, if any change.
For normal temps adding fan does only minimal improvements. Like 5C at most. But if you are running on higher temps, difference can be up to 10-15C.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
