please help me with cs:go
Solved by Hecknologist,
The only thing real money will get you is skins for the guns in-game. All the guns in the game can be found in the buy menu, and will show the skins you have equipped in your inventory.
It's important to note that not all guns are available on each team, as some are team specific. They can however, be used by any team if picked up off the ground.
You can also have 2 skins equipped simultaneously for guns that are buy-able on both teams by setting one skin for each team (eg: AWP, asiimov skin equipped to CT and redline equipped to T).
