Had this ISP, router and such for about 12 years, and the price hasn't changed, and I know I can get better for what I pay for.
I'm deciding to talk to my ISP to get an upgrade etc. For 60-70 dollars a month, what do you guys think the minimum internet speed I should be getting? I'm not really wanting to end up paying to much for something so little again.
https://linustechtips.com/topic/425076-isp-need-advice/
Which country are you in?
Intel Core i7 4770k - 2x Geforce GTX 780 - MSI Z87 MPower Max - Corsair H60 - 8GB Avexir Core Series MPower Yellow + 4gb no-brand DDR3 - Corsair Obsidian 750d - AData XPG SX900 256gb SSD - Seagate Barracuda 3TB (7200 RPM) - Hitachi 250GB 2.5in HDD (3200 RPM) - WD HDD 160GB extracted from iMac via black magic (no specified RPM) - ASUS VG248QE 144HZ 3d Vision Monitor - Logitech G602 - Ducky Shine 3 TKL - AKG 172 HD Headphones - Xperia z2 - Sony Noise canceling earphones -  Nikon D5200 With Bundled Lenses - Windows 7 Home Premium - Blue Snowball iCE - Acer Aspire X with a broken case, AMD A6, and Raijintek Aidos CPU heatsink
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705525
Location? ISP name? ISP packages for that kind of money? What's your current speed?
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705527
I checked on a website and it was 15 mbps.
My ISP is Bell Canada.
How much do you pay now? I had 12mb but I recently upgraded I'm getting 25mbps for only $5 USD more a month, and if I want to upgrade to 45mbps I need to pay $10 more a month.
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705550
Now that's what I call a ripoff (by internet speed packaging prices that are available here).
I assume you're going for the Fibe 15 plan, since that's the only one that fits the bill and I also assume you'll get unlimited data (which is $10 more)
While I know how badly Canadians get screwed over on internet plans, that looks pretty crappy. I'd go for Fibe 25, tbh (then again I have a gigabit plan that I pay like $15 for)
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705568
60-70$ a month???
I hope that's 10Gbps connection then....
I pay 10$ a month for 100Mbps in Latvia
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705659
Shaw and telus for 60 give you 25 down and shaw doesn't enforce the caps
Bell dosent service where Shaw and Telus service.
90 dollars.
TekSavvy has 30 down 2.5 up in BC for $50, it should be cheaper in Eastern Canada.
Intel Core i5-4460 3.2GHz Turbo 3.5GHz | 8GB Kingston DDR3-1333 | MSI Radeon R7 370 OC to 1020mhz | EVGA Supernova NEX B1 750W | GIGABYTE GA-B85-D3H | Inwin Velocity OEM Case | 120mm broken fan
Vancouver, BC | O Canada
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705664
I have fibe 25, it's reliable.
Don't bother with Rogers, they rip you off  (and put bandwidth limits that you can only get rid of by paying an extra 30 dollars)
The bandwidth limits on Rogers half the time you aren't even warned if you exceed them, so there will be a nice surprise on your bill.
Also bell fibe has really nice upload speeds, so if you are into streaming or whatever then they should work fine.
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705715
I  am in Canada as well. I am with Shaw (they pretty much have a monopoly where I am). I am paying almost 80 dollars for an extremely reliable 25 megabit down and 2 up. My speeds are often above 25 for download so I can't complain.
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705730
You only get 25 mpbs tho with fibe 25.
What I like about Bell is that you can pay an extra 10 dollars and you'll get unlimited.
Problem is that it's only 25 mpbs.
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705745
I honestly would rather have a stable 25 mbps than have an unstable 50mbps.
Also I think that the 10 dollars thing is only if you have another thing with them (example: phone and internet, tv and internet, or all 3)
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705760
Telus, and Rodger got a couple of ok deals.
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705780
I'll call em today thanks for the help!
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5705784
Watch out for the real price of the plan. Mine said 35 dollars and in fine print, it said for the first 6 months. It is most likely the same for others.
https://linustechtips.com/topic/425076-isp-need-advice/#findComment-5715059
