So getting solid 75FPS and always below 50ms ping
but at  random times in the match i will "rubber band" or tp to my position a couple seconds ago.
why and any fix?
i have seen other people ingame have this issue.
Valve server or community?
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703396
Make a rubber band ball
But really run this, then check for packet loss (Idk how with CSGO, only with LoL)
http://netalyzr.icsi.berkeley.edu/
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703412
I am not sure if you have the same problem as me but sometime when i play csgo i freeze for like a second.
well it freezes then i TP back to where i was.
and teammates have reported me during that time
standing still
shooting randomly
etc.
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703430
i only play Comp. so Comp Servers
happened to me on windows 7  8.1 and 10 on wifi /Ethernet.
Odd as it sounds. Update audio drivers.. specially if Realtek
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703442
hmmm i don't think that is it.
i went a period with the Microsoft generic audio drivers and still happened AND my drivers all up to date
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703459
I had this issue while playing on Wifi at a friends house. Plugged in an ethernet cable and forgot to turn off Wifi turns out my computer was still running on Wifi.
Make absolutely sure you're on ethernet while gaming. Only way to go!
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703460
Tested both no dif other than a 2ms ping dif.
the latency on wifi in my vs ethernet is a 1ms difference sooooooo.
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5703468
packet loss is the issue.
Packet loss is indeed the reason why you are rubberbanding. I have the same issue as you described, and I figured out it has to do with the components in your pc or laptop. If you type 'net_graph 1' in console, you will see the var-value fluctuate between 1 and maybe 30. You'll also see the packetloss happening, spiking to 40% or higher. A smooth experience would be 0% packetloss and a stable var of 1-4.
I have not found any fix, but my guess would be that it has to do with low VRAM speeds and thus a low end gpu. Mine is a quadro 2000m so that would totally make sense at it is not designed for gaming.
Gl my friend
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5712486
Gl my friend
#intelhd2000
https://linustechtips.com/topic/424914-csgo-rubber-band-problem/#findComment-5712493
