This will be my first pc I've decided to just go and get a pretty good pc for less than $2000 dollars I'll leave the list of componetnts down below.
Intel 4790k
Asus gtx 980 sc acx 2.0
Corsair 750d case
Windows 10 home 64-bit
Asus z87 pro lga 1150 motherboard
Noctua nh-u12 fan cooler
Asus 24x dvd-rw optical drive
Corsair vengeance 16gb ram ddr3 1600mhz
Corsair cx750 builder series power supply
Wd 1tb green hard drive
https://linustechtips.com/topic/424751-first-pc/
Very nice list. Kappa
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/424751-first-pc/#findComment-5701380
What a nice list.
Here is my pc specs:
The Main/Wendel
I7 4770k 4.3 Ghz
Z87 Plus
16gb Ballistix Sport
Nividia K600
256
Ssd
2tb Hdd
4 AF120
EVGA 430w
H100i
Various Other fans
The Gaming Pc/Mindy
CPU:I5 4690k
GPU: PNY GTX 660 SLI
RAM: ADATA XPG V2 8Gb
MOBO: Z87-A
PSU: CX750m
120gb
ssd and 1tb wd blue
Source 210 Windows
212 Evo
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/424751-first-pc/#findComment-5701394
~snip~
Hey there Huntyoudown20,
The build generally looks good. Is this a gaming build or you are planning on doing other things?
WD Green may not be he best choice for a standalone boot drive. I would suggest to check out some SSDs for great performance, short laoding and boot times and very responsive system. Also, if you prefer to stay with a HDD I would suggest to check out WD Blue and WD Black as better-performance alternatives:
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/424751-first-pc/#findComment-5706168
Couple questions:
Why a z87 motherboard? 4790K is a Haswell Refresh chip which may not work on that motherboard out of the box... I'd suggest getting a z97 motherboard to prevent any issues. They should be similarly priced anyway?
750d is going to be humongous and your build inside will look tiny. To each his own I guess, but I'd get a smaller case. Then use the money left over on a 980ti :)
No SSD?
4690k will equal 4790k when it comes to gaming performance in 99% of scenario's. If gaming is your primary concern, save money there to buy yourself an SSD boot drive.
This is what I'd do:
PCPartPicker part list: http://pcpartpicker.com/p/xjt6zy
Price breakdown by merchant: http://pcpartpicker.com/p/xjt6zy/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.99 @ SuperBiiz)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.99 @ Mwave)
Motherboard: Asus Z97-E/USB3.1 ATX LGA1150 Motherboard  ($123.99 @ SuperBiiz)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($81.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.95 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ NCIX US)
Video Card: EVGA GeForce GTX 980 Ti 6GB Video Card  ($643.99 @ SuperBiiz)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case  ($110.99 @ SuperBiiz)
Power Supply: Corsair 760W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($178.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($91.75 @ OutletPC)
Total: $1694.52
Generated by PCPartPicker 2015-08-07 08:05 EDT-0400
Desktop:     Core i7-9700K @ 5.1GHz all-core = ASRock Z390 Taichi Ultimate = 16GB HyperX Predator DDR4 @ 3600MHz = Asus ROG Strix 3060ti (non LHR) = Samsung 970 EVO 500GB M.2 SSD = ASUS PG279Q
Notebook:  Clevo P651RG-G = Core i7 6820HK = 16GB HyperX Impact DDR4 2133MHz = GTX 980M = 1080p IPS G-Sync = Samsung SM951 256GB M.2 SSD + Samsung 850 Pro 256GB SSD
https://linustechtips.com/topic/424751-first-pc/#findComment-5707420
