The problem is that spotify doesn't allow me to control it using my keyboards media keys. Pause, play, stop, next song....
https://linustechtips.com/topic/424597-problem-with-spotify/
It doesnt work with media keys for me either its not media key compatible I guess
They media keys work on this same keyboard but on other pc what is running windows 10. Not on this what is running 7.
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5699581
Check you have all drivers instealled? maybe try reinstall spotify
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5699596
Re-installed spotify already. All drivers are installed. The media play bind what i have binded to my logitech mouse doesn't work either.
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5699606
Strange because my Spotify does let me use media controls. (I'm using a CM Storm Devastator)
samee for me on my cougar k700
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5699646
do you have any other media players open because i've found some override spotify while open.
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5699650
Nothing but spotify and still not working.
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5699758
Hmm, odd. If you reinstalled drivers and Spotify, it should have fixed it. Can you tell me if you have Chrome and if so, do you have the app "Google Play"? If so, please disable and see if a reboot fixes the issue.
It works fine for me...in Linux and Windows 7 + 10.
https://linustechtips.com/topic/424597-problem-with-spotify/#findComment-5704690
