Hello people !
So, a friend of the family built me this computer a few years ago, and has been working extremely well in all games I've ever played (CS:GO, WoW, GW2, LoL, DotA2) You know, the normal stuff.
But now, it won't really run anything.
I get idle temperatures on about 50 degrees celsius, as soon as i start a game up (For this example I'm using the game Evolve on medium setting) Even just in the pre-game menues I'm reaching around 80 degrees celsium and in-game playing I can get all the way up to 90 if not more.
The CPU fan is running around 3000 RPM at that point, and I have never heard my machine make that much noise before.
Today I've taken the stock heatsink off and cleaned it out and applied new thermal compound from Coolermaster, but without that much effect.
Specs are:
CPU: QuadCore Intel Core i7-2600k
CPU Cooler: Stock
RAM: 4x  Kingston HyperX 4GB
Motherboard: Intel Burrage DP67BG
GPU: Asus GTX560 Ti
Power Supply: Antec TruePower 750
Case: Corsair 600T
OS: Windows 7 Home Premium 64-bit
Any help is much appriciated !
https://linustechtips.com/topic/424578-cpu-overheating/
Hello people !
Specs are:
CPU Cooler: Stock
GPU: Asus GTX560 Ti
Case: Corsair 600T
New thermal paste maybe? It sounds like the contact between the CPU and heatsink isn't too great.
*EDIT*
Just saw you tried that...
you familiar with delidding?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/424578-cpu-overheating/#findComment-5699277
A 212 evo will be a lot better then stock. Make sure to pick up some Thermal Paste too. Remember, rice size dot
part of the problem is the stock cooler
But will that for sure solve the problem ?
Because the weird thing is that I have been gaming on this PC for 2-3 years now and played all these games without a problem before now.
I have literally never worried or heard anything about my CPU overheating before the Intel application started giving me warning a few days ago.
https://linustechtips.com/topic/424578-cpu-overheating/#findComment-5699354
*EDIT*
You can't delid Sandy Bridge CPUs. The IHS are soldered to the CPU die, and don't use TIM like Ivy Bridge and beyond.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/424578-cpu-overheating/#findComment-5699363
I didn't know that... Thanks!
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/424578-cpu-overheating/#findComment-5699688
