okay guys in my pc i have a corsair cs750m power supply! and custom lighting solution i made, i bought a 2m long 12V LED strp and wired that into a 12V switch which sits at the back of my pc. then its all wired into the 12V and ground pins on the molex connector on the back of the pc, all of this is wired into a connector for easy disconnect so i can remove the door! now now and again it will go from bright (receiving all 12V) to a lower brightness it will stay like that no matter how much i move the case, or wriggle wires it will stay like that, even switching it of and on, will make no difference! then all of a sudden it will brightnedd back up again, the lower brightness could last for 30 seconds could last 25 minutes, and it becomes detracting! so any ideas?
Check out my current projects: Selling site (Click Here)
If($reply == "for me to see"){
   $action = "Quote me!";
}else{
   $action = "Leave me alone!";
https://linustechtips.com/topic/424472-lights-flickering/
Is it while the PC is under load?
no not necessarily
}else{
https://linustechtips.com/topic/424472-lights-flickering/#findComment-5698196
may be the LED's are on there way out i had NZXT blue LED's before and after a while they started flickering so i got new ones and all good now
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/424472-lights-flickering/#findComment-5703050
