So some of you might know that I switch to Linux for some reasons and it comes with LibreOffice.
I started using LibreOffice yesterday and I got some problem. (I'm still adapting)
So whenever I put numbering after bullet it goes back to one....
Should be like this:
1. Test
- Test
2. Hello
- Hello
3. Ok
- Ok
But it becomes like this instead:
1. Test
- Test
1. Hello
- Hello
1. Ok
- Ok
Anybody knows how to fix this?
Using Ubuntu Gnome 15.04.
LibreOffice version: 4.4.2.2
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/424450-libreoffice-numbering-problem/
One way to do it could be to make list full list (10 lines) and then separate them. Problem is when using line breaker where you add double line. It stops the numbering or clears it. LibreOffice has other weirdness in lists. Like I haven't found good way to go one level back. The buttons and shortcuts which would work in MS Word and in Google Drive, don't in LibreOffice.
I'll try to check further into to this and maybe find solution to my problems as well.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Ok. I tested with my laptop and for me numbering works right as it should. I have older version, 4.2.8.2., maybe thats the difference.
Didn't find solution to my problem yet.
