Hey guys,
So here's the deal. This is an MSI refurbished GTX 580 Twin Frozr II and since I've had it for a while, one of the fans has gone out and my temps have rocketed to an excess of 100c which is far too high obviously. It also don't help that I live in the desert so this is quite an issue as it's been exacerbated so easily. Anyways I dust my computer out regularly with compressed air and also reapply thermal paste regularly with arctic silver 5 (old school I know) and it doesn't quite help enough. I've even removed my case components to give the PC as much fresh air as possible with fans in my room. Helps, but I don't want to have to do that. No overclocking, etc.
So my question for you all, would be, if I am to replace my heatsink shroud on my graphics card, what should I replace it with? I don't currently have a liquid cooler radiator, so I can't use that NZXT liquid cooler doo-dad thingy. I don't want it to take up too much space, because I have been thinking about grabbing another 580, but I certainly wouldn't with these kind of temperatures.
OR, do I just replace the fan on the current heatsink?
Let me know your overall thoughts. I can also provide pictures of my setup if need-be.
https://linustechtips.com/topic/424394-gtx-580-overheating-options/
just get a new  modern card
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Go on E bay, Amazon or whatever and you will be sure to find a GTX 580 heat sink. Also think about if two GTX 580's will do the job considering they both use a lot of power and output a lot of heat so maybe consider buying a GTX 970 or something.
Aaron... The Spicy Turnip
Hey guys,
Probably not even worth salvaging. You could probably pick up a more modern used card that would provide higher performance and power efficiency.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
Regular reapplications of TIM are not necessary, not unless you mean every 6 months or so. That being said the Twin Frozer cooler was one of the best available for the 580 so if that cant keep it cool then your options are
1. Extreme air cooler(aftermarket)
2. Watercooling
3. Getting a different card.
Personally I think 3 would be the best option as you cant even keep one cool right now so trying to keep two cool would be impossible.
"The of and to a in is I that it for you was with on as have but be they"
How hot does it get?
My 560 reaches 90 now that I've OC-ed it.
Hey guys,
 snip
try and see if you can get just the cooler from a similar pcb 580 if you dont have the $$ to drop on a new modern card.  I just got one actually (few years late lol) because my cousin was cleaning out his closet and I threw it in my system yesterday just for curiosity's sake and I was rather impressed with the performance!  I had to make the reference style blower scream to keep it under 80c while gaming but it did it ok. check ebay and whatnot for coolers or cheap cards even. and if @Gofspar says it needs delidded then he's probably right.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
You need to delid it, 580 and older had a IHS on the GPU die, the TIM under the IHS is dryed out.
You forgot to mention possible ramifications of attempting such an act, you know that whole "killing your hardware" part.
2. Watercooling
Yes by regular reapplications I mean every Summer or so. It gets hot here.
102 Celsius, resulting in failure
Never heard of a GTX 580 being de-lidded, but if that's a serious reply, then I would consider it.
@Sirslicey
Watecooling would be your best option, really.
Or a new GPU.
look into one of those AIO GPU coolers, maybe that'll work better and not cost so much
