Hello I am new to this forum so if i posted this in the wrong area then please tell me.
I need help to figure out why my computer shuts down with the slightest overclock.
Specs:
Intel i5 3570k
Cooler master hyper 212 evo
Msi z77a gd45
8gb G-Skill 1600 ram
Powecolor HD 5780
Antect high current 520w 80plus bronze
Samsung 840 Evo 128GB
2 1tb seagate baracuda drive
Lg cd/dvd read writer
5 120mm fans
1 200mm fan
So when I turn oc genie on or use custom oc settings the computer wont load the operating system and cant read the boot drive. If os loads the computer shuts down after a while.
https://linustechtips.com/topic/424174-need-opinions/
Specs:
Intel i5 3570k
Msi z87 gd45
Powecolor HD 5780
5 120mm fans
1 200mm fan
maybe you have a horrible chip for overclocks and it needs more voltage ?
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5694626
Can it get solved with a better psu? The chip workes with oc genie when the computer runs without the graphics card
wait so if you unplug your gpu the pc boots but when you have it plugged in it crashes ?
http://www.tomshardware.com/reviews/powercolor-5870-lcs,2481-13.html thgat card likes its power
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5694670
Yup when using on board it works fine. Im assuming looking at the tomshardware graph that my psu is too little?
how long have you had your system ?
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5694851
I built the system june of 2012 when ivy bridge first launched so around 3 years. The gpu I had if for around 5 years?
and you just started having this problem ?
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5694952
i didnt want to overlock the system at first then i felt the urge to overclock the system so i tried and found out this problem.
so did you how much did you oc ur cpu and did you oc ur gpu ?
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5695023
i went a like 0.5 volts oc? and a bit on the multplier like 1-3. i did not oc the gpu
try stock voltage ?
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5695329
It works fine at stock voltage
then leave it at stock
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5695517
so stock voltage with ur oc works ? or just stock
and a car thread !
https://linustechtips.com/topic/424174-need-opinions/#findComment-5695519
So is no one going to point out the ivy bridge 3570k on a Z87 board?
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/424174-need-opinions/#findComment-5696698
ah sht mistype =) thanks for pointing it out
No worries. Which cpu is it? 4670k?
https://linustechtips.com/topic/424174-need-opinions/#findComment-5698050
