What motherboard do you have?
Can you see if you have a "Slow-mode" switch on your motherboard?
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5693885
i have the Z97S SLI KRAIT EDITION motherboard
where would i find the slow mode setting if there is one?
Probably either above the 24 pin, or towards the very bottom of the motherboard.
IDK if that board has one, but make sure if it does, that it's not enabled.  Slow mode locks the CPU at 800 mhz, for benchmarking & Ln2 purposes that I won't explain :P
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5694191
just checked. i dont believe it does
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5694225
Hmm, that was my only idea :/ sorry friend :(
I'd say try doing a benchmark to see how you score vs people at stock, to see if it's just misreading the speed.
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5694233
Make sure windows isn't on power saver mode lol (more common on laptops but seen it happen)
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5694696
When you say the flash drive isn't recognized...do you mean it can't see the flash drive at all? The BIOS file needs to be put into root for it to be recognized.
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695529
computer can see the drive fine but when im in the bios it just dosent see it at all for some reaspm
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695579
It's not listed in the boot menu either?
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695601
also im not sure what you mean by root lol. all the files where taken out of the folder and put on the usb if thats what you mean (clueless)
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695607
Root is the beginning of the file system of the partition. Imagine entering a partition when you double click on it and stopping there. That is root.
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695616
i just checked. its recognized in the boot menu, and in the bios where it shows whats connected in each port it shows the usb but when i try to flash the bios it says "media not found"
Make sure the BIOS file is put in root as I explained above. It can't be sitting in any folders.
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695684
they are in root if im understanding correctly
Which file are you using? There's also an executable that can be run after you extract the ZIP folder.
https://linustechtips.com/topic/424115-cpu-stuck-at-800mhz/#findComment-5695718
