My Galaxy 560ti has been overheating like crazy it use to run crazy hot like 108*C and then would die. i replaced TIM (dumb idea) and it runs cooler now but its still 99-102*C. Galaxy wont take it back because i replaced TIM any good VGA coolers?
"Peek-a-boo, you ****s, you!"
https://linustechtips.com/topic/4238-galaxy-560ti-overheating-issue/
Did you try adjusting your fan curve on your gpu? I think MSI Afterburner works for all gpus. And 100 degress is very bad... you should try to keep it below 60 degrees... Make sure your fans are spinning smoothly like killerx525 said.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
what cooler came on your card? is it a reference cooler or is it an aftermarket cooler? Also a link to your specific card would be very helpful.
Corsair Obsidian 800D | Msi GD-80 z68 | Intel Core i72600k (stock speeds at the moment) | Msi Gtx 570 twin frozr III | 8GB Corsair Dominator @1600mHz | Coolermaster evo 212 temporary) | Cooled by Gelid Wings | Intel SRT smart caching | Windows 7 ultimate x64
Sounds like it busted , my MSI GTX560 TI done the same, i checked cooler, fans all working fine , soon as i put it though Kombustor the temps when up to 100*c . so tried my other TI as i had it in sli and the temp was all ok on the second card.
that is an internal exhaust card. Is your case ambient temperature pretty cool? If it gets toasty inside of your case and you aren't exhausting the hot air, then that would mean you are trying to cool off your graphics card with air that is already hot.
  • 3 weeks later...
If Galaxy truly wont replace it, an aftermarket cooler is probably your best option. Arctic has some good options.
2500k | Z68-UD3H-B3 | GTX 570 Classified + Accelero Xtreme III | MX 200 250GB + Seagate 500GB | R4 | Seasonic 660W Plattinum | 8GB G Skill | Acer K272HUL + 2 x Dell P2417H, Rosewill dual mount, HP 22bw | Mackie CR3, ATH-M50X | DAS Keyboard | Mobile: X1 Carbon, Nexus 6P, LG G3, Samsung S5, Nexus 7 (2013)
