MicroATX case that fits inside IKEA Kallax shelf
Notn4
Hi,
I'm about to build a mATX build and have pretty much all components figured out except for the case so I thought that someone here might have some great ideas.
The case would need to fit inside a IKEA Kallax (they used to be called Expedit) shelf which is a 33cm*33cm cube, the depth doesn't really matter as long as it's not over 45cm. The case also will need to have room for a 280x and a 240mm AIO cooler. Other stuff like optical drive bays and side windows doesn't matter.
So far I've found the Thermaltake core v21 and it would seem to fit just barely if I remove its rubber feet but this is somewhat pushing it and I'd love to hear some suggestions!
Corsair Carbide Air 240
BitFenix Phenom Micro-ATX
Sharkoon CA-M (Sort)
Lian Li PC-V358 (Sølv)
Lian Li PC-V354
Silverstone Sugo SG02-F
Antec P50
Jonsbo V3+
Lian Li PC-V354
Antec P50
Jonsbo V3+
Thanks! Will look into these.
  • 1 year later...
Sorry to revive an older thread, but Notn4, what did you end up going with? In the exact same boat as you in terms of needs. I have a Sugo SG02, but cooling in that is extremely cramped - no way to add a AIO cooler in there.
